Can I direct (side) vent a residential boiler?
Sean_10
Sean_10 Member Posts: 1
I have a Peerless oil burning boiler that was venting through an old chimney stack that needs to be dismantled for a number of reasons. Because of this I need to find another method of venting my boiler. The easiest way for me to do this seems to be to direct (side) vent the unit. I can't find any information in the boiler installation guide that tells me I can vent it this way.
I'm a carpenter with very little experience in thia area so any help would be greatly appreciated.
Many thanks,
Sean
  • pitman9
    pitman9 Member Posts: 74
    Yes, you can use a power vent.
    > this way.
    > Many thanks, Sean
  • ed wallace
    ed wallace Member Posts: 1,612
    direct vent
    yes it can be done using a power vent from field controls
  • pitman9
    I only use Tjernlund for power venting. Their web site is
    http://www.tjernlund.com/oilsidewall.htm
    You want the SS2.
