sparcomix versions
Dave Kliman
Member Posts: 11
i was looking at this document:
http://giveme5.honeywell.com/Product/mixingvalve/AM%20Series%20Mixing%20Valve%20-%20Tech%20lit%20and%20installation.pdf
http://72.14.207.104/search?q=cache:157uYRvFMHQJ:giveme5.honeywell.com/Product/mixingvalve/AM%2520Series%2520Mixing%2520Valve%2520-%2520Tech%2520lit%2520and%2520installation.pdf+honeywell+sparcomix+valve+types+180&hl=en
(same document, 2nd link is the html version from google)
I wanted to get the version R for my radiant loops, but the plumbing supply gave me a couple of the C's. the different models are B, 60-100F; C, 80-120F; STD, 100-145F; and R 80-180F.
I wanted the R so i could turn it all the way to 180 for filling the loops and purging. also i wanted the max temp to be high enough to deal with the r value of the floors in some zones.
ok so my question:
the plumbing supply distributor said that i can use a C as an R by simply removing a small plastic piece that keeps the dial from turning all the way in one direction or another. I don't want to break the seal on the top of the knob without knowing for sure that's correct. so should i keep the C's i have and break the seal and break off a little plastic tab? or do i have to purchase a couple R's because they have some other differences besides that?
-Dave
ok so my question:
-Dave
i am sorta wondering what the benifit would really be....
to You the habby homeowner. i have a B sparky mixer on my radiant...do you have like Super Thick slabs,deeply buried tubing? if so a porortional miixer might not be as good as an investment as an I series -R from Taco.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 106 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 104 Geothermal
- 69 Pipe Deterioration
- 953 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
