hot water off of steam
Bildo
Member Posts: 12
I am replacing a steam boiler that has a zone of hot water BB. Iam am putting the hot water zone on a flat plate heat exchanger. The customer also wants an indirect. Is it better to run the indirect off of the HX or should I run it off of the boiler directly?
boiler
I would run the indirect off of the boiler. You will have considerably better HW production.0 -
use an...
everhot, a flatplate x will plug up0 -
I would not...
use the flat plate HX...I promise you it will plug. I have had a superstor indirect coil plug up using condensate. kpc
- 86.8K THE MAIN WALL
- 56 Biomass
- 106 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 104 Geothermal
- 69 Pipe Deterioration
- 953 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
