Uncorked my first Ultra oil....
Xc8p2dC
Member Posts: 41
Do the high and low sides have preset temps? or are they each individually adjustable
This boiler looks fine!!!
Unpacked this baby and took some pics. I'll post pics. of the final installation later in the week.
Am adding the Advanced Feature Module to it also, as I will be running both high temp. and low temp. zones with this boiler.
The AFM is an add on to this boiler and does not come with the boiler.
This will make cleanings something that I can actually tolerate. One heck of a chunk of C.I. though, make sure the steps to the basement are up to it!!!!
Checkout the screw in leveling feet... they even tilt for uneven surfaces....
Floyd0 -
nice...should be fun:)0 -
First saw this
boiler at a Trade show. Looks like WM's answer to the German boilers. The advanced control module has a built in Variable Speed circ connection as I recall. Keep us posted. WW
I don't know....
but I'll be setting that up shortly and I'll get back to you..
Floyd0 -
last I checked, the Germans were not asking any questions.
You remember the axion "Lead or follow, just get out of the way"? The Germans say to whoever will "Follow".0 -
That AFM looks suspicially like a Tekmar without the display. Is it available for the Ultra Gas?0 -
Upon further review...
Yes,.... the mix temp. and the boiler demand temp. are individually adjustable. They also each have their own adjustable heating curve. That is just a small portion of what all this control will do, there are many, many features included in there.
Floyd0 -
It's possible...
I have no idea who may be building this control for WM....
The Ultra gas has many similar features built right into the onboard madule that the gas boiler comes with. The Var. injection feature is not on the gas yet, I hear tell of things like that happening and multiple setpoints being available. There are many parameters already included in the gas boiler that are waiting to be "unlocked" if I could only crack the code, or get the password out of WM.....I have been told, that will be comming.....sooon.
Floyd0 -
Ultra codes
Has any body tried a code other than the 05 using the Ultra interface. You can see (they are greyed out) other settings in the interface but as we all now you can't get to them0 -
Floyd
Thanks, probably, heading in that direction myself0 -
Nice!!!
I like
How much does this baby go for?0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 954 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
