Need help on slecting a boiler
Scott Price_2
Member Posts: 6
Gentleman, although i have followed dan holohan and the wall for a number of years, Im in need of assitance in selecting a boiler for an old friend who recently purchased a fixer-upper wit no heat. As cost is a problem his budget is limited im trying to set him up with a low mass stand down boiler and will be installing baseboard hot water probably one room at a time. I have looked so far a Slant Fin XL2000 castiron boiler, and New Yorker boiler steel FR-HGS, also Crown Freeport-CT4 and last but not least Thermo Dynamics Boiler LM-100. As i work in commercial refigeration and installation i have been out of the heating loop for some time and dont know what is good, bad or ugly. please reply to the above email address. If i can help with refrigeration problems let me know.
Scott Price
Scott Price
go with a steel boiler
they are probably the least expensive and they do stand up well as long as the system is well maintained. You will have to check with your supplier about what is available. I always liked the Dunkirk if you are looking for basic cast iron, but then I lived jsut outside of where they were made. reliable and cost effective, but support availability is important as well0 -
Boiler slection
Thanks for the input. I'm leaning to the New Yorker FR. I have
worked on a few over the years,they seem to hold up.0
- 87K THE MAIN WALL
- 113 Chimneys & Flues
- 106 Geothermal
- 981 Plumbing
- 388 Solar
