Thank you to Burnham
John_173
Member Posts: 63
Thanks for your post.
Peace to you.
Edited addition of 16 January:
Jim, I'm not a Burnham employee. I just appreciated your post. It makes a refreshing change from certain others.
I'm nothing more than an owner of a residential steam boiler (not Burnham). I happily would have a Megasteam or two in my basement, particularly if they were LPG-fired. (No, I don't mean to re-start that discussion, either!)
Peace to you.
Thank You to Burnham
On Saturday we received a no heat call! Upon arrival we found a gas valve that was passing when the valve was off. The system belonged to a very sick lady .She is terminal with cancer. The valve was ordered first thing Monday and we expected delivery early Tuesday morning . Well today we found that the valve was not sent and this lady had to look forward to another night of no heat. I called customer service and went over our problem . An hour later I was told that someone from Burnham was on the way from the factory with the valve. They hand delivered the valve to our supplier with in 4 hours. Our lady is warm and they helped make her last days a little nicer .
Thank you for caring Burnham and God bless .0 -
Thanks for the great customer support!0
