Question for Bill@Honeywell
Bill W@Honeywell
Member Posts: 164
will work. Just make sure that you "tell" the thermostat that it is going to be working cooling only. It's spelled out in the installer setup codes. Part numbers are TH8110U1003(VisionPro touch screen) or the TH6110D1021(FocusPro soft key) model. Wire it R,Y & G. R being 24 volt power, Y is the cooling contactor, G is the fan relay.TH8110 is either 7 day or 5&2, the Focus Pro is 5-1-1 programming. Thanks for using our products!
Bill,
What programmable t'stat would you recommend for the following cooling-only configuration: Residential, whole house Spacepak, t'stat location on second floor, desire 5/2 programming (min). I know it isn't cooling season yet, but I have the opportunity to work on the system now.
Thanks, Dave0
