oil burner leaking
ed wallace
ed wallace Member Posts: 1,612
could be a loose nozzle,bad nozzle adapter,pump seal,nozzle line or bad nozzle
  • GW
    GW Member Posts: 5,137
    drip
    I installed a furnace with an AFG, it's dripping under the gun; I'm guessing it could only be coming from the nozzle connection. Do I need a new nozzle line? I already tightened down the nozzle (not too tight, but tight enough)
    Thanks,
    Gary
    Gary Wilson
    Wilson Services, Inc
    Northampton, MA
    gary@wilsonph.com
  • burnerman_2
    burnerman_2 Member Posts: 297
    check the flare
    i have had a few of these that were rough look at the end of the drawer assemly where the nozzle line goes on i noticed a few of these have burrs and i feel cause the line to leak after it has been on and off a few times if the flare is bad no matter how much u tighten it the thing will drip try the new line royboy
  • burnerman_2
    check the flare
  • burnerman_2
    check the flare
  • Paul Fredricks_3
    Paul Fredricks_3 Member Posts: 1,556
    Make sure the gasket around the ignitor is intact. A bad gasket can cause the air/oil mix to swirl back into the burner.
