pex tubing staplers, wich one?
Don Regan
Member Posts: 43
Why would you want to use a stapler???
tubing staplers
were just starting out in the hydronic end of the trade and are tooling up. Wanted to get some input on wich pex tubing stapler is most prefered in the field.Any input?
Thanks Tom@sullivan H&A0 -
Staple up or staple down?
stapling down0 -
Staple down
For my Plated Staple ups(which i try to avoid) i use a Senco.
For staple downs (which i rather see a Paneling system like Roth boards or warmboard)I rent a staple gun from a supply house.
Was thinking of purchasing a Roof stapler at Home depot and making a guide for the tubing. maybe even a remote trigger so one can stand up while stapling.. I think someone makes this now, can't remeber who.0 -
ISM
is the oem stapler manufacture for the stand up handle i have. the tube guide is bolted on the front and is somewhat wide. I bought mine 10 years ago, I like it because i am used to it. I bought 3 bostich staplers with tube guides from some another pex company, my guys like it better for weight and the guide is much smaller.0 -
Because -
It's so much cheaper than Crete-heat. Yes that's with ALL costs considered.
I like the concept of your product but just can't justify the cost.0
