Set Back Controller
Barry_6
Barry_6 Member Posts: 13
I'd like to install a set back controller on a Burnham 2PV boiler. I have a hybrid system. The boiler feeds 2 radient loops, 3 baseboard loops and an indirect domestic all off a 1" primary loop. I've tried to conserve energy by setting the boiler temp to what the weather forcasts predict but more often than not the system isn't set high enough to keep the house warm or the house over heats at the end of a cycle. Any suggestions for dependable controllers?
  • Weezbo
    Weezbo Member Posts: 6,231
    sounds like you are the operating control...
    the radiant loops need slightly different temps than the indirect and the baseboard. are you controlling the radiant with trv's ,injection, 4 way mixing three way proportional valves? as it is all off the same headder, do you have prioritization?
