Pipe sizing(supply & return) for Carrier 42ck fan coil ac units
RJ_4
Member Posts: 484
If your a member of the U.A. you can order this book on line (Hydronic Heating and Cooling.) It's got it all. $40.00. www.ua.org
a/c fan coil units
I am wondering about the proper way to size supply and return piping for the installation of Carrier 42ck fan coil a/c units. I have the york manual and I also have the carrier guide and it gives an excellent formula for doing so however I am confused on the true way of finding hydrostatic lift of the cooling tower and also do the pipes need to be pitched at all. I am also wondering if there are high pressure valves available due to the high operating pressure of the system and if so, where can I buy them. Thank you very much for your time.0 -
thanx
thank you very much. I will do just that0
- 123 Chimneys & Flues
