Fan replacement
Steamhead (in transit)
Member Posts: 6,688
as I understand it there have been problems with some of these fans, but the factory is doing a good job of supporting their units. They might also be able to give you some things to look for, so the fan won't fail again.
"Steamhead"
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
"Steamhead"
Fan replacement
I get to change out my first draft inducer fan in a munchkin m80 and I was wondering if there are any tricks or special tools needed to tackle this project.
Terry0 -
If I remember correctly,...
There is an adjustable damper on the housing itself that has to be set to the correct differential pressure setting of the manufacturer. Take a quick look and see if you can see one...
Mike T.0 -
fans
The air is fixed in these units.
Yea, I wasn't sure Ted.
I did see one like that a while ago, but thought it might help.
Mike T.0 -
revise
I should have said that the swirl plate is fixed. No adjustment there. The only thing that changes is the fan speed.
