Infloor thermostat settings
Ken_40
Member Posts: 1,310
we found the in-concrete radiant very quick to respond and so, day/night - programmables are great!
However, in the staple up portion, the lag time and nature of the area involved (LR & DR area - where we spend up to ~16 hrs. a day) makes little sense. The tiled areas (K, 2 baths and entryway) are very fast responding - so a D/N is a great controller there.
The shortest answer?
Depends on the response time up - and down. If you can drop a room temp by 5 degrees in under 2 hours, D/N 'stats are great! If 3 hrs. or more to do a 5 degree spread, you might want to stick with a T87-type.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=504&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
is it best to leave a programmable thermostat set at a constant temp or vary
it night/day?
Whole house infloor, including basement
Sleeper sand in upper floors
Wisconsin
4400 sq ft.
ICF walls, icenene roof0 -
OD Reset system?
Does your system have out door reset? If it does it automatically varies the temp of the water in the floors and is actually more efficient and comfortable than setting back the stat. IMHO0 -
sand??
you could try it? but if your tubing is in loose sand the delay in heating/cooling might be a bear to deal with and make you unhappy.0
- 167 Indoor-Air Quality
