sight glass washers/gaskets
Brian_62
Member Posts: 5
I want to take the slight glass out to clean it. I imagine that I'll need new washers or gaskets, and I want to have them on hand before I start the job. Are they just regular washers? Can I figure out what size to get by measuring the OD of the glass? Any other tips or gotchas would be welcome. I'm obviously new to this.
Of the last 4 glasses I removed & replaced, none needed new rubber gaskets / washers. Just re-tighten it just enough to stop any leaks and be careful...I had a couple with VERY sharp ends...They work with compression and are usually just over hand tight.
TimJust a guy running some pipes.0 -
Washers
Any plumbing & Heating supply house will have them all day long. A decent hardware store may have some too. Sid Harveys, RE Michel, FW Webb , etc. etc.
5/8" is most common. You can get the nut, washer, and little flat brass washer in a package.
You will need a glass cutter also. There are probably 15 different styles. It is a personal preference thing. Buy more than gauge glass, if you are out of practice, most people don't get it on the first try. Practice makes perfect.0 -
> etc. etc.
> a package.
> perfect.
Thanks Bill. How do I know what brand I have? I've looked at the knobs and don't see a company name.
Is the glass cutter you mentioned in case I break the glass I have or do I need it no matter what?0 -
Thanks for the warning and tightening advice, Tim.0 -
The skinny...
Yes, no and yes... Isolate the sight glass and loosen the upper and lower compression nuts. Under the nuts you should see thin brass washers and the sight glass "rubbers". You need the washers between the nuts and rubbers so the rubbers don't tear or bunch up when you tighten the nuts. Remove the glass and take to your favorite supply house. Many are 5/8" but why take the chance if you are removing the glass anyway? They will sell you new rubbers, new washers if the last guy left them out, and a new glass if you managed to chip/ crack/ drop yours. If you replace the glass you might end up paying for a longer one, ask nice for them to cut it if you don't own a sight glass cutter. I've never had luck getting the glass to seal when reusing the rubbers... others might but I'd rather replace than have a callback or wipe out the sight glass valves with a weeper. Good Luck0 -
Sight gauges are a nominal size
Typo sorry about that0 -
Any good heating and supply house will set you up, carefully remove the old piece in question and take it to the counter guy if he's good hell set you up with a new gauge glass cut to the proper length and the edges sanded smooth as there razor sharp and the proper white neoprene oil-resistant synthetic rubber washers with new brass washers.
Very little money and time for a lifetime of performance.
Not a bad deal eh?
James0 -
I also found that if you wet the glass first after loosening the nut, the rubber will slide much more easily down ( or up ) the glass. Makes it very easy.
Brian
Brian, sorry those are names of heating suppliers.
The glass is very generic, no name brand required.
I too have been able to reuse washers, but they may have been only a year old or two. Old washers become hard and brittle because of the constant 212-215° temperature.
This is really easy once you have done it.0 -
Thanks for help with sight glass washers
Thanks everyone. I went to the local Ferguson shop. While they were able to order the insulation I needed for a fair price, they didn't even know what a sight glass was. So the hunt continues.0
- 125 Chimneys & Flues
- 121 Geothermal
- 396 Solar
