Deep Seal Trap
Anthony Menafro
Member Posts: 200
Donny is correct. Some inspectors make a determination as to whether you can use a deep seal(6inches in this case) trap or a trap primer depending on the use of the space in question. Example; Will the floor with the drain be wet mopped on a regular basis or the fixture supplying the trap primer be used regularly? Contact the local plumbing inspector, he'll tell you.
Anthony Menafro
Anthony Menafro
Deep Seal Trap
NY residential code P3201.2 calls for a deep seal trap or a trap primer for a floor drain. I am going to create a deep seal trap in pvc but I cannot find how deep needs to be for it to be an acceptable deep seal trap. It is a 2" trap for a floor drain. The code states a normal trap must be between 2" and 4" in depth. Does this mean anything over 4" is a deep seal design? Is there a set depth for a deep seal trap? Anyone else out there know how deep I should make the trap?
Thanks
Gary0 -
trap seal
many plumbing inspectors require trap primers [speaking from expreience] so before installing a deap seal trap my advise would be to check with the "AHJ"0 -
Im now showing my inexperience but what is "AHJ"?0 -
AHJ =
Authority Having Jurisdiction, or
Another Hardheaded Jerk depending upon your personal experience...
ME0
