Honeywell ST 9162 EFT
carol_3
Member Posts: 397
For Roger I have an email address of rogdarschill@comcast.net. It worked last summer!
What are the expected voltages
from the ST 9162 to the ECM direct current motor control. I have been in the past getting around 14 volts AC. A recent check on two of them showed voltages of 35 to 40 volts. Any ideas, what is also interesting is they work on both voltages without failure. These are two jobs that I am monitoring for other problems and just wondered about these voltage. That is from the P2 connector on that board by the way. It is being used with the Two Stage SmartValve SV9540 Q.0 -
To the
top.0 -
To the
top.0 -
PWM
Tim, I think (but hey, what do I know?) that the connector you're talking about drives ECM controllers in variable-speed mode. The speed output to an ECM controller is delivered pulse-width modulated (PWM), at some low-ish DC voltage (10?) Most volt/multimeters don't know anything about PWM and happily misinterpret it as AC, giving false readings.
Sound good?0 -
You are correct Mark
that signal is piggybacked on the actual voltage signal to the ECM controller. Honeywell at one time gave voltage readings (AC) for this control to be 14 volts AC plus or minus .1 volt. I am getting readings on several jobs that are erratic but there is no visible problem with the system. I thought Carol could check with Honeywell Engineering for a correct answer as to what we should measure. These are on a Comfortmaker Furnace NTVM/VNK series.0 -
Back to the
top.0 -
Tim--because of your past affiliation with the Honeywell Source program, you probably have closer ties with the OEM gas and ignition folks at Honeywell than I do. I suggest that you network with your contacts and get an answer!0 -
Carol, I talked with
Honeywell Tech services and they could not give me an answer. I called Bill Ribble he was not sure. I then tried to get hold of Jim Cole and Roger Schilling but my phone numbers are out of date I guess. I left Source in 1999 so many of those folks have retired.
Any help with a name/number would be greatly appreciated.0 -
Interesting I just had
another one of these with different voltages and no one can give me an answer - very frustrating to say the least.
Anyone have any ideas?0 -
Thanks Carol
that is a different one than I had. I will try and reach him.0
- 117 Geothermal
