Buderus Help Needed
Rodney Summers
Member Posts: 748
i am going to install a room sensor for indoor feedback
and use constant circulation.
on days when i use my wood stove can i turn the dial on the room sensor all the way down and have a switch to turn the pumps off so the boiler stays hot but since it See's the room sensor happy it wont fire the boiler for a very long time till the boiler temp reaches 40 :-)
can someone show me how to wire this correctly cant i just use a standard wall switch mounted next to my room sensor and hook it in line with my pumps.
thank you
thank you
Which model of Boiler are you using?
Good Luck
Dobber0 -
g115-28 with 2107 control and a lt 160 tank riello f3 40 series :-)
thank you0
