Taco TFP Sizing
Tony_23
Member Posts: 1,033
Your voicemail has a message on it.
I couldn't hang out waiting today, so didn't leave a message earlier.
Alternate output chart ?
Trying to size a brazed plate HX for a small load. Source is an outside wood boiler which varies in supply temp from 150-170 deg. Would like to get 15KBTUH out at 140 deg. The 15K is max required and normally would be 1/2 of that.0 -
Joe M ?
Call me to size
Hi Tony
Thank you for considering the Taco brazed plate heat exchanger. I will be happy to help you size an exchanger that will meet your design criteria. Feel free to call me at your convenience.
Joe Mattiello
Technical Support Technician
Tel. 401-942-8000 X 484
Fax. 401-942-2360
joemat@taco-hvac.com
- 50 Industry Classes
