Gas boiler supply air
You should be able to find all the C/A requirements for a Burnham PVG <A HREF="http://www.burnham.com/PDF/PVG_I&O.pdf"> here. </A><BR>It`s on pages 6 & 7.<BR><BR>Dave
Hi All,
Hope you had a relaxing holiday. A theoretical question: I have a Burnham PVG-4 gas fired boiler of 100KBTU. If this unit were installed in a sealed room (no outside air infiltration) how big an opening would be needed to satisfy the demand for combustion air? Also, is there a way to determine the CFM of the air flow? Thanks for all your great help in the past, Roland.0
- 120 Geothermal
