Hot Water Heater Noise
Hi,
My work shop is located in the boiler room and I have a separate oil fired water heater. Not all the time but occasionally when I'm in the shop as the water heater reached temperature and shuts off there is a noise like someone dropped a handfull of broken cement.
The unit works fine - no leaks. I guess it's about 7 years old.
Any ideas of what this noise is or where it comes from?
Is this the start of something bad?
Thanks
  • Gene_3
    Gene_3 Member Posts: 289
    could be
    what you may be hearing is the heat surging through mud or remnants of the glass coating in the bottom of the tank, it will stop shortly after the burner shuts off, please make sure the unit is not over heating, water heaters can become missiles if they superheat.
    You see water boils at 210*F at atmospheric pressure, at 100psi-{avg city water} it will be superheated before the latent heat can turn the water to steam and viola' instant missile. Watts has a video on it.
    This is why Watts invented the Temperature/Pressure Relief Valve to cover both, homes used to get leveled.
    In your case check the water temp coming out,make sure it's not over 120. Also check your T/P Valve yearly. Most techs won't check them because they leak after you check them, a duh, put in a new one, takes 2 minutes.
    If it is mud and the glass lining you can try flushing the drain, be prepared with a replacement drain valve but the tanks life is limited.
  • Frank M. Tricarico
    Frank M. Tricarico Member Posts: 25
    Gene,
    Thanks. It make sense. My pressure relief valve started blowing every once and a while and still does although infrequently.
    It's been on my list to pick up a new valve - but not the priority list.
    I'll change it out over the weekend. Hopefully, the glass lining is not gone.
  • Gene_3
    if it is blowing off
    it is doing it's job--somethings wrong, not the relief valve, unit may be over heating, shut it down and call a pro--see the story below for why.
    So please be sure to understand --if your heater is making noises and the t/p valve is blowing off something is really wrong!!!!!!!!! the t/p is doing it's job --it is supposed to release for high temp or high pressure conditions or both!!!!!!!!!!
    Call a pro and do not DO NOT PLUG ANY RELIEF VALVE EVER!!
    I found this a while back, can't remember what paper or where but it is imperitive that these warnings be heeded.
    July 9, 2003
    Defective heater puts hole in roof
    By ROB McCALLUM
    H&N Staff Writer
    Johnna Bruner was fast asleep when an explosion ripped through her home on Greensprings Drive in the middle of the night.
    It was a malfunctioning water heater, which built up pressure until it turned into a bomb that rocketed up from the basement, ripped a hole in the living room floor, and vaulted through the ceiling to land on the roof next to the satellite dish.
    The explosion that occurred about 1 a.m. June 30 shook the house off its foundation and left its contents in tatters.
    Bruner and her fiance, Casey McClin, considered themselves lucky to have survived.
    "We were in a water bed at the time and [the explosion] sort of tidal waved us out," said Bruner, who lives in the 2100 block of Greensprings Drive. "There was so much steam in the living room we thought there was a fire."
    Klamath County plumbing inspector Dennis Stone said he was surprised at the damage caused by the 20-gallon water heater.
    "I've been in the trade going on 33 years and I've never seen anything like it," Stone said "It looked like a bunker-buster bomb went off in there, like in Iraq."
    According to Stone, the pressure release valve on the water heater either corroded shut or failed altogether. When the thermostat continued to function, pressure built up inside the heater until it burst.
    "We'd heard some godawful noises about an hour before it happened," Bruner said. "So we went down and read the instructions on the water heater and it said to turn the water breaker off, so we did."
    Around 1 a.m., the water heater blasted off from its spot in the basement, tore through the living room floor and ceiling, just feet from the sleeping Bruner and McClin. The heater then landed above the porch, knocking down the chimney in the process.
    The heater was hot enough to create steam, meaning it was at least 220 degrees. Melted insulation was found throughout the house.
    When the heater initially exploded, a wave of pressure blew the garage door onto Green Springs Drive. According to Stone, this may have saved Bruner and McClin.
    "They told us that if the garage door wasn't there, we'd be dead," Bruner said. "It was such a crappy garage door it blew out instead of blowing us up."
    "The two people in there were lucky," Stone said. "Most of the pressure went out instead of up into the house. It still moved walls off the foundation."
    Damage estimates to the property have yet to be determined by insurance companies. Bruner said that she and her fiance lost more than $26,000 in the accident.
    Exploding water heaters are rare but not unheard of, according to Stone.
    "It's not common, but when it does happen it's pretty damaging," Stone said. "It's something that people just don't think about. If the right circumstances hit, this is what happens."
    Homeowners can prevent their water heaters from exploding with proper maintenance.
    "If somebody has a heater that's 10 to 15 years old, they should check it's condition and maybe think about replacing it," Stone said. "A replacement is really pretty reasonable in cost. If people are leery about what they need to do, a licensed plumber can give them an estimate."
    Stone said that newer water heaters have more advanced pressure release valves. Any time a used water heater is resold, the release valve is replaced.
    "Sometimes people see that their release valve is leaking, so instead of replacing it, they clog it," Stone said. "They've just made themselves a bomb."
    Meanwhile, Bruner and McClin are staying with relatives until they can find a permanent home.
    "Usually when you think of an water heater blowing up you think of some water flooding a basement," Bruner said. "But this literally blew up."
    Reporter Rob McCallum can be reached at 885-4413 or (800) 275-0982, or by e-mail at rmccallum@heraldandnews.com.
