Soot Particulate Size
Norm Harvey
Member Posts: 684
Zero
Thats what there should be.
According to The Engineering Toolbox oil smoke particle size varies from 0.03 - 1 micron.
As someone else already said, such should not be produced by oil burning appliances.0 -
no soot,
in theory yes, but then all the oil people here suggest yearly cleaning????? therefore soot must be somewhat of a problem.0 -
Oil and yearly cleaning
Yearly cleaning for oil systems isn't strictly related to soot. Black carbon caused by unburned fuel is soot, a no no and not present in a good running system. But the need for cleaning or a tune up is to check for proper ignition, change filters, and test for proper combustion efficiency. As well as checking safety devices. Cleaning the heat exchanger of sulphur residual and any crust formed by condensation present is necessary. There is a misnomer gas systems doe not need annual service but they have ignition and safety systems that often get overlooked. Not to mention secondary heat exchangers in condensing boilers.
Leo0 -
This is somewhat different question.
what type of oil burning combustion chamber? And what Type application? Before or After the Stack burners? might also then ask When in the combustion cycle...0
- 167 Indoor-Air Quality
