need help sizing a/c
steve_28
Member Posts: 5
I am in the process of building a new home. The style is geodesic dome. I am trying to figure out how to size the a/c for it. I am wondering if anyone can point me to a formula or program that might work on that type of house? Or if anyone would like to try I can give you the construction/climate details.
Thanks,
Steve
PS: I have attached a couple of pictures of my house
Thanks,
Steve
interesting
Looking at your new house, the lower level seems easy as in total area, plus windows, exposure average deg. day etc... Do you know the area or total volume of the dome? I'm sure there had to be measurements when in the building process. I personally haven't sized a house like this, but I am interested in the final results.
Mike T0 -
dome
the total volume of the dome it self is 21,845 cu.ft. plus it sits on a 2 ft. riser wall , the dome is 45 ft. in dia. it is a fairly open floor plan, I was planning on using a 3 or 4 zone mini split ac system.0 -
The accurate way
is a thorough Manual J. You can get a homeowner's registration of HVAC-Calc for $49. It's a very easy program plus you can give Don a call for any questions. Considering how much you are going to spend on minis, this is a cheap investment.
http://www.hvac-calc.com/main.asp0 -
dome
do you think this program would work on this style of home0 -
Steve
Just got off the phone with Don from the above mentioned,...I tol him about your post. Check out the sight. He knows about your questions...
Mike T.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 996 Plumbing
- 391 Solar
- 55 Water Quality
