Large Diameter Pex?
Norm Harvey
Norm Harvey Member Posts: 684
RST Inc in Norwood, MA is a rep for Rehau and that have all kinds of large diameter stuff, insulated and uninsulated in their show room. If you give them a call they may be able to point you to a supplier. 781-320-9910
  • Eric Johnson
    Eric Johnson Member Posts: 174
    Large Diameter Pex?
    I'm looking for a source for 1.5" O2 barrier Pex or Pex-al. The usual suppliers don't seem to have any, but my usual suppliers are pretty limited.
    And Happy New Year to all the Wallies.
  • rehau
    Norms right, Rehau has pex up to 2" in diameter insulated and uninsulated.
  • Weezbo
    Weezbo Member Posts: 6,231
    Keller
    is a name of a wholesaler ...they carry Rehau.
    one thing though that i think you ought to know not all 1 1/2 is the same wall thickness. the insulated seems to have a different wall dimension ...that requires a somewhat different connector..some friends found that wood boiler manufacturer that reps some green o barrier tubing has 1 1/2 fittings that co mingle :)
    good luck *~/:)
