Large Diameter Pex?
Norm Harvey
Member Posts: 684
RST Inc in Norwood, MA is a rep for Rehau and that have all kinds of large diameter stuff, insulated and uninsulated in their show room. If you give them a call they may be able to point you to a supplier. 781-320-9910
Large Diameter Pex?
I'm looking for a source for 1.5" O2 barrier Pex or Pex-al. The usual suppliers don't seem to have any, but my usual suppliers are pretty limited.
And Happy New Year to all the Wallies.0 -
rehau
Norms right, Rehau has pex up to 2" in diameter insulated and uninsulated.0 -
Keller
is a name of a wholesaler ...they carry Rehau.
one thing though that i think you ought to know not all 1 1/2 is the same wall thickness. the insulated seems to have a different wall dimension ...that requires a somewhat different connector..some friends found that wood boiler manufacturer that reps some green o barrier tubing has 1 1/2 fittings that co mingle
good luck *~/:)0
- 120 Geothermal
