Stripped air vent tapping
Motivated Amateur
Member Posts: 20
I had to replace an old gorton air vent, which came out quite smoothly. When I went to screw in a new vent, it could barely catch the threads - as if it were bored out wider at some point. The threads on the old gorton are the same as a new one. Is there any way to close up the hole a bit, to get the new vent to screw in? I already tried wrapping the vent threads 10 times in teflon tape. (And no, I don't know how that old vent stayed in all these years!) Thanks
Is this a main vent or a rad vent
Sorry 'bout not specifying- it's a rad vent0 -
drill...
and tap it for a 1/4 NPT thread. Then install a 1/4" x 1/8" bushing. Make sure to use the correct drill size (I think 7/16")
thanks`
Thanks, John. I looked up what an NPT thread is. At the risk of sounding oblivious, how do I get the bushing into the drilled out tap? Is it self-threading?0 -
drill & tap
Richard,
It would be a two-part operation. First, drill the hole with the appropriate size drill. Then another tool called a 'tap' would be used to cut the 1/4" NPT threads. After clean-up, the bushing would then screw into the freshly 'tapped' threads.
If this would be your first time with a pipe tap, you may want to find a friend that's had some experience or find a pro to help. best of luck.
- 167 Indoor-Air Quality
