0 Degree F Heat Pump?
don_52
don_52 Member Posts: 199
Gentlemen of the Wall,
A fellow wrote about some zero degree f heat pumps.
I have read up on the DOE Region V heat pumps from;
http://www.nyletherm.com/spaceheating.htm
Any others at or close to this in the mainstream?
Going to AHR Show tomorrow and would like a heads up,
if possible.
Regards, db
  • Wethead7
    Wethead7 Member Posts: 170
    Low temp Heatpump
    I have not seen any but That product could be useful in my market area.
    Maybe meet up at the show.
    Mike
  • David_5
    David_5 Member Posts: 250
    heatpump
    You can get more heat out of the system if the outdoor coil is bigger. This allows the system to absorb more heat from the outside for delivery inside. I wonder what the booster compressor is. Two speed compressors have already been done for heatpumps.
    David
  • This content has been removed.
  • don_52
    David B., Mind sharing a...
    Particular brand, I was going to the show today after
    a meeting downtown ( Chicago ), the meeting took on a
    life of it's own and well....
    Some day's I miss twistin' wrenches so bad I could weep,
    know what I mean?
    Cheers, db
