fuel oil day tanks
J.C.A._3
Member Posts: 2,980
Like soil, I gotta stick to my roots.... Keep on teaching brother. Chris
day tanks
Looking for options on fuel oil day tanks, for smaller jobs. In otherwords don't need a big simplex tank w/ all the bells and whistles.
thanks,
Steve0 -
Pressurized Lines
You can delete the tank ,use OSVs ,lift pump and pressure switches. Relief by pass for larger jobs.0 -
DIdn't really want to go that route.
......with the lift pump, etc.... This is a commercial application. Am looking for a smaller daytank and will pipe it back to the big underground tank outside. Primary reason for doing this is their existing system is trying to lift the oil around 18' or so, and then run horizonal through the building 100' to the boiler room (3/4" single line). Currently they have tigerloops on both boilers, and still only one will stay running when temps get down around zero. I don't believe they would have a problem if I install pump up to a daytank, (inside the building, w/ return line to outside tank), and have the boilers pull it from there.
Just looking at options for possible cheaper and smaller, but good quality day tanks.
thanks, Steve0 -
thanks, Steve0 -
You might try....
The Firedragons site, and ask for Bruce Marshall A.K.A. bruski there. Oil Tech Talk might also get you an answer. Hope this helped.(I know a few but don't think they'll cover the sizes you need!) Chris
Thanks Chris, I appreciate you mentioning the site
Here's another site you can find lots of great info and options for your situation.
Suntec Installation & Service Manual
And by all means plase feel free to stop by Oil Tech Talk
Like The Wall, We are happy to share what we can when ever we can.
Your friend in the industry,
Alan R. Mercurio
www.oiltechtalk.com
don't know if it's legal(Probably not) but I used to see expansion tanks used as day tanks.
ED0
- 110 Chimneys & Flues
- 980 Plumbing
- 387 Solar
- 17 Recall Announcements
