Check valve for main vent?
Problem: Radiator "whoosh" sounds from air vent at end of steam cycle. Possible cause: Gorton main vents not opening as fast as the radiator vents, forcing vacuum to be filled from radiator making sounds that are annoying.
Someone on this site suggested installing a check valve in line with the main vent to allow air in if there is vacuum.
Can anyone provide their opinion and advice. Exactly what should I be asking for at the supply house. Are there concerns with this approach? I use three Gorton #1s on each of two mains with Gorton radiator vents. One-pipe steam with new boiler.
Steve from Denver, CO
