L8148A1124 differential
Ron Schroeder
Member Posts: 995
Thanks Carol. I'll add the L8148A1124 to my list of aquastats with a differential of 15 degrees.
Hi Carol,
What is the high limit differential for the L8148A1124? I have found the differential for about 6 other versions of the L8148A but not this one.
Thanks,
Ron0 -
The only one I have info on is the A1017, which is 8 degrees. Is yours an OEM model?0 -
Hi Carol,
Yes it came with a boiler but I have seen them on several boiler brands with the same full model number. I have seen at least 6 different types L8148's. The specs that I have seen are either 8 degrees or 15 degrees depending on the last 4 numbers. I just need to know what this version is.
Thanks,
Ron0 -
This one's 15 degrees.0 -
Ron, would you email me at carol.fey@honeywell.com. I'd like to get more info from you about what you know about all these controllers.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
