What's the max BTUs delivered through 1\"?
But the basic thing to know is how much flow a given pipe size can handle. Once you have that in your head, you no longer need a chart.
Here are my guidlines (conservative I admit; many will allow more water per size) for maximum allowable flow in gallons per minute:
1/2" = 1.5
3/4" = 3.0
1" = 5.0
1-1/4" = 9.0
1-1/2" = 18.0
Next factor is the temperature drop, ("delta-T"). Conventionally this is 20 degrees in many systems, could be higher, 30 or 40 degrees, could be less, 10 or 15. 20 is a good balance of heat output without moving too much water.
At a 20 degree delta-T, every gallon of water per minute will carry the potential for 10,000 BTU's per hour (BTUH).
The shorthand calculation is:
GPM x 500 x Delta-T (degrees F) = BTUH
If you use glycol anti-freeze, the 500 number will drop by about 10% depending on concentration. But for discussion let's stick with water.
Thus if you have a 5 GPM flow rate at 20 degrees Delta-T = 50,000 BTUH. (Your 1-inch pipe)
If you have a 30 degree Delta-T you can get 75,000 BTUH, 40 degrees, 100,000.
But 20 degrees does make the math easy, doesn't it?
Hope this helps.
Brad
  • Fred Almeida
    Fred Almeida Member Posts: 12
    Searched through some of my old studying material and just couldn't find the ratings of max BTUs delivered through hydronic piping.
    Can anyone refer where to find this material?
  • Empire_2
    Empire_2 Member Posts: 2,340
    Great explanation
    I would add that although you can increase or decrerase your "delta T" the idea is to keep to a minimum, velocity noise from excessive flo and poor performance from the lack of flow. That is why we have given BTU and GPM ranges for a given pipe size.
  • Brad White_26
    Brad White_26 Member Posts: 35
    An excellent reminder, Mike
    It is all within a range (why we were given judgement and free will I suppose? Yeah, that's it! For hydronics!)
    Thanks!
    Brad
