duct ?
Empire_2
Member Posts: 2,340
The supply house that sells equipment should have these availiable.
duct ?
installing a forced air system. have the heat loss done need the charts for sizeing the duct does anyone know where to find these ?0 -
You can use...
You can use the tables in the back of the Manual J book to obtain the diameter of the duct you will need for each area the system serves. From there, you will need to convert from the round size to its equivalent square or rectangular duct size.
As Mike mentioned you can obtain a "Ductulator" from your local supply house for about $20.
By the way, in order to properly size the ducts, you will need to determine the friction rate for the specific air distribution system you are installing. Using an incorrect friction rate can result in inadequate system operation.
Remember to measure twice and saw once.0
