Need nuts and bolts help
explain the near-boiler piping. If you look at the picture working from the bottom up and pulling off the primary loop, there's a Taco mixing valve for the basement slab (no outdoor reset), a supply and return for the 2nd and 3rd floor radiators (green pump, no outdoor reset) and on top is the injection system for the 1st floor staple-up (brown pump, with outdoor reset).
We installed this system in 2002 and it's been flawless (knock on wood).
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=53&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
