All I want for Christmas is a genuine steam expert!
Mad Dog_2
Member Posts: 7,011
I'm sure he could handle it. I would consult up there, but you will have to find a good local guy to do the corrective work. Mad Dog
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=299&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Finding a real steam techy
Merry Christmas!
Does anyone know of a steam heat expert in the Hudson Valley area?
Thanks!
SB0 -
Define Hudson Valley
Long river with steep sides...
If you are in the Saratoga Springs area, Darin Cook is excellent.
Even if you are not in the Saratoga Springs area, Darin is still excellent but you may be too far away.0 -
dan's book
i recieved dan's book for christmas looked at it a bit. this will be a gret help to anyone workin on steam royboy0 -
Hudson Valley Steam Expert
Dan!
Thanks for your info! I'll get in touch but, Saratoga Springs is probably too far - 2 plus hours, one way, I think. I am in Beacon, 12508, at the intersection of 84 and 9D. I really appreciate your help.
Happy Holidays,
S. Botsford
steam tech
You are not too far from upper Fairfield/lower litchfield counties in Conn. I bet youcan find one there0 -
Close by
I am in Newburgh, tell me more about your system and problem, I can recomend someone.0 -
You are possibly within range of Triple Crown Heating
steam man Matt Sweeney, at least for a consult. He has been known to travel far from his Long Island base for special situations. Check him out on the site's find-a-pro under the resources menu.
Good luck,
David0 -
trolley
I lived in Newbugh as a kid, what happened to that steep trolly that was on the Beacon side? i remeber the days when there was only one bridge.
Happy steam pro searching!
Thanks for the plug David
and Happy New Year! Mad Dog
If Darin has the time, grab him
Mad Dog
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
