Swapping an old radiator for new type
Dan_15
Dan_15 Member Posts: 388
I asked about Runtal radiators before, and I need a little bit of follow-up advice. We are remodeling 2 bathrooms which each currently have a cast iron Burnham radiant radiator inset into the wall. Im wondering if I can just swap the the Burnham cast iron for Runtal omnipanel radiators. My system is Buderus G215/4 with R2107 and outdoor reset, plus indoor reset. The piping is an ex-gravity system, and I have no idea if the rads are in serial or parallel or what. The current bathroom rads heat up just fine, if not even a little too hot. Assuming that I get them sized properly, can I just swap the old for the new Runtal? Do I need to be thinking about anything else? Thanks.
