Nozzle Size
lee_7
Member Posts: 457
why was boiler overfired? I am not familiar with this boiler, is it a multiple fired boiler ( three different nozzles for one boiler)? If not, nozzle should be lowered to correct size, pump pressure checked and set per specs and combustion effiency test taken.
Nozzle Size
With oil prices where they are, I have a question.
My Burnham PV84S steam boiler calls for a 0.85 x 60A nozzle, if I read the specs correctly.
I have been using a 1.00 60B Delavan nozzle.
Is that efficient, or should it be changed out for the nozzle spec'd out by Burnham?
Thanks for any help.
Bruhl0 -
I don't believe that it ever "overfired", although I don't know what that means. It has the nozzle that the installer put in place originaly.
It is a standard Burnham boiler with a Becket Model AFG burner.
For some reason it has the 1.00 60B Delavan installed.
Thanks again.
Bruhl
overfired means nozzle size bigger then is spec'd by manfuacturer. If paperwork states .85 x 60a and it has a 1.00 x 60 b, Something is wrong. Unless manufacturer says that is a correct nozzle size, I would "downfire" to .85 nozzle and adjust combustion with combustion analyzer. Just because that is nozzle installer put in does not make it correct.0 -
a Burnham PV84S...
looks like it's a packaged(?) -- (i.e preassembled, vs. knocked down for shipping), V8 series, 4 section, steam boiler, rated 1.05 GPH (or 147,000 BTU/hr) input per Burnham's I&O manual.
Depending on the burner it uses a 0.85 or 0.90 GPH (at 100 psi) nozzle with a pump pressure of 140-150 psi for an actual firing rate 1.02 to 1.08 GPH.
Beckett: 0.85x60°A @ 140, Carlin: 0.85x60°B @ 150, or Riello: 0.90x80°B @ 145
Has someone perhaps installed a 1.00 GPH thinking it was fired at 100 psi (or actually turned it down to 100 psi) vs. the 140 psi spec'd (as it has the Beckett). You sure it's not a 0.85 nozzle *delivering* 1.0 GPH (due to the higher pump pressure setting)?
If the nozzle and/or pump pressure are changed it will have to be readjusted w/ instruments, as others have pointed out, to get the combustion right.0 -
Thank you 3lees. just the information that I needed.
Thanks for helping out.
Bruhl0 -
Hello scrook, and 3lees,
The boiler sticker says:
model number PV84ST-HBUR
firing rate light oil #2 1.05 GPH
DOE HTG CAP 127 MBH
NET MBR RATINGS STEAM 396 SQ FT
STEAM 95 MBH
Maximum nozzle size 1.00 GPH
Manual says:
V8 SERIES OIL- FIRED BOILER
in Table 6
Becket AFG [other ststs for Carlin and Riello]
V84S
firing rate GHP 1.05
head setting V1 [0]
air shutter 10
air band .5
NOZZLE GPH x Angle Type 0.85 x 60A
Pump Pressure 140
I don't have the slightest idea why there is a 1.00 60B Delavan installed, but that is what was installed per my recent service invoice, and what the original service person marked on the service sticker.
That's all I know, but I wanted to do it right, not just what was done last time.
Thanks again and best regards.
Bruhl0
- 167 Indoor-Air Quality
