Radiators like Niagra Falls
Steamhead
Member Posts: 17,638
One-pipe systems were generally designed to return condensate by gravity. Unless there is radiation below the "A" dimension, I doubt if the pump is needed.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=157&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Consulting
Consulting
Hello Wallies,
I went to a job this A.M. at a group home and found some poor maintenance man dealing with a radiator that had the air vent removed and water was spilling out of the radiator like I have never seen before.
We went downstairs to look at the boiler, I found a HB Smith G210 residential steam boiler with a McDonnell Miller 150 LWCO/ pump controller hooked up to a Skidmore PC-6 condensate tank. The water in the sight glass was bouncing wildly, the boiler was not firing. The PC-6 was adding water to the boiler fairly frequently.
Does the MM150 and PC6 seem like overkill on a small steam boiler???Any input would be appreciated.
Thank you,
Wild Bill
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 945 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
