Furnace not blowing heat, but will blow cool?
burnerman_2
Member Posts: 297
ok does no matter if it is oil or gas if the fan is operating the unit has power to it. it is off on safty one of a dozen things out of oil bad transformer plugged nozzle bad primary cad cell ect best idea of the night call your service man earlier monday morning royboy
At some point yesterday, the furnace stopped coming on periodically to blow heat, even though the house was noticeably cooling off. After a few hours, we tried switching the setting on the thermostat from Auto to Fan, and air did start coming through the vents, but only cool air, even though the temperature on the thermostat was set high.
We tried setting the heat extra high in case some kind of temperature gauge in the system may have been off-kilter; we tried flipping the switch in the circuit panel off and on. Nothing is making any difference.
Any home-repair-knowledgeable people out there have thoughts on what might be happening?0 -
no go
oil or gas furnace ?0 -
one Biggie..often overlooked...
when did you last purchase fuel for it?
if it is gas it may have plenty of fuel yet need attention .it could be something simple . best to get a tech to look into it...0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
