Taco 007
a 007 circ will run 40F OVER AMBIENT WATER TEMP.
It will be TOO HOT to touch.
  • saxman251
    saxman251 Member Posts: 17
    Hot stuff...
    My step-father and I put in a wm-ultra this weekend, and everything seems to be running fine, but the 007 circulator that came with it gets HOT, like it hurts to touch it hot. Is this normal?
    Thanks,
    Ryan
  • Brad White_9
    Brad White_9 Member Posts: 2,440
    All water-lubricated circulators get hot
    This is normal. It may bring to mind why it is maybe too hot, could your HW discharge settings be higher than necessary?
    The circulator does create heat of it's own and the surface temperature would be somewhat higher than the water inside it. The lower your water temperature the cooler the circulator will be -and the more energy you will save assuming it still heats your house!
  • Empire_2
    Empire_2 Member Posts: 2,340
    Brad's correct.
    When I first installed a wet rotor pump, that was my concern also. Taco advised that it's normal as long as you are within operating specs. of the pump. See literature.
  • Joe Mattiello_2
    Joe Mattiello_2 Member Posts: 94
    240 degrees max operating temperature
    The 007, or any of the wet rotor pumps run hot, but that is normal, and will not be a detriment to the pump.
    Joe Mattiello
    Technical Support Technician
    Tel. 401-942-8000 X 484
    Fax. 401-942-2360
    1160 Cranston St
    Cranston, RI 02920
    joemat@taco-hvac.com
  • Jim_47
    Jim_47 Member Posts: 244
    A hot 007
    One thing to check is if it is circulating water. I was called to a new job of another contractor because he could not fix it. He was not circulating water, circulator was hot, but when you put a screwdriver to it as a stethescope you heard humming not water movement. This was caused by a glob of solder that had worked its way thru the baseboard and jammed up the rotor. The other guy refused to think that the circulator was not circulating.
  • Garritt
    Garritt Member Posts: 27
    007
    Taco 00 series will run hot when running at long periods of time. When the pumps are "air locked" the temperature will be very hot. We just installed a taco 1919c1 circ that locked rotor on us and pulled 41 amps on the amp meter. That pump was so hot we couldnt remove it till it cooled down.
  • Weezbo
    Weezbo Member Posts: 6,231
    air eliminaton is KEY....
    WET ROTOR NO LIKEY AIR.
    the plastic impellers aint all that keen on "debris" wood chips Christmas tinsel)from reaming ( solder foam in the pipe cement sheetrock slerm those things make the pump slave overtime... flushing the system proper air elimination(even on potable) all out removal of the cartridge and impeller will often bring things back to reasonable temps at the pump.
    large pumps 20 HP and there abouts are designed to leak slightly to lubricate the shaft of the pump over tightening the packing causes binding and additional "heat" due to friction ...i have repaired a few pumps that were bound this way.the motor drags and overheats causing thermal overloads.....
