Distance from BB
hr
Member Posts: 6,106
is the space below the fins to allow the cooler air to pass up througb the elements and out the top. Carpet jammed under baseboard really upsets this convective heat movment.
Chairs and couches close to bb will not hurt the output IF the cool air can be pulled under the furniture. Dust ruffle or anything the limits the air flow will limit the output.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hot rod
What is the ideal distance objects should sit from copper fin baseboard to get proper convection???0 -
The farther
The better. Iwas always told by "old timers" that the frontal distance s/b equivalent to the vertical height as a minimum. JMO0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 945 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
