Temp Logging
Weezbo
Weezbo Member Posts: 6,231
Hobo just crunched out another white paper...
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    The 1-wire system used at www.ourcoolhouse.com makes this feasible if near the sensor limit.
    Live updates once per minute.
    Will be able to use that pulse gas meter, Mark...
  • Weezbo
    Mike i looked at the read out and i question why the water temp
    is so high..and i wonder why it seems to be stuck on about 20* D T .... for all the work that they put into the system i would think they would have shot for lower water temps at this time of year...
    numbers just for spacing and estimation
    Hobo would have required a mortgage...
