Looking for a gas burner with direct outdoor air... Boilerpro
Boilerpro_5
Member Posts: 407
If I am using direct outdoor air, I would suspect there is a chance of freezing, since the chimney draft is pulling some air through the boiler even if the burner is off. the boiler is going to be used in a situation with long, deep setbacks..... a church heated once a week.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=393&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
I want to use a gas burner that has direct outdoor combustion air to the burner on an oil steam boiler. Looking for about 300,000 input. Any suggstions?
Boilerpro
here is my thought....
a Carlin EZ gas...similar to a oil burner set up...w/ a air boot ...output is around 275k....kpc
powreflame
powerflame the JR series may be another option, nothing in front of the air inlet but not sure if ducting it is an option.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
