HELP! IDENTITY THEFT!
Dave_4
Member Posts: 1,404
It didn't happen this time, so maybe it was a glitch that got fixed, but . . .
why were posts I made assigned other person's login and email addresses?
What are the posts you made that were assigned different info?
That info may be helpfull to the system administrators trying to find out what happened.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"There was an error rendering this rich post.
Cookies and Cheap Drama
This has happened before. The explanation had to do if someone sent you a URL or vice versa, I forget. When that happens your posts take on that person's identity.
Odd, I know, but it happened to me too. Just change your sign in information back before you send. I think that was the fix.
I never saw any such posts- As Norm suggests, where are they?
I do not think anyone deliberately would want to be you
"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
How should I take that?
No one would want to be me? Why not? ;-)
What I have been noticing is that my email has been getting, just for the past week or so, a lot of Wall replies, to threads I have never visited.
Furthermore, I was doing posts, with the forum's software inserting someone else's name and email address in the message header spaces where mine should be. I made certain to make corrections, but it is that stuff that made me suspect glitches.0 -
Crush your cookies...
No, not toss your cookies. Well, OK, I guess it would be toss your cookies. The Wall reads the cookies in your cookie file. Some times and somehow, they get corrupted. When that happens, you take on a new name. Clear out your cookies and you'll return to normal programming...
Speaking of which, time to get back to 0's and 1's.
TTFN
ME0 -
Ditto,...
I have noticed this as well, as well as a few posts that were not mine!0 -
"WOW" could there be another BRAD WHITE out there0 -
Cookie issues...
... can arise here as a result of searching. Recently when unable to find something using the Wall's Search function, I went to Google and performed an advanced search in the domain forums.invision.net. When the desired match was clicked on, two things happened. First, font type and size changed. Also, when I tried to reply, I morphed into whoever it was that had posted the found item. A complete invision.net cookie dump fixed that.
The negative side effect of deleting invision.net cookies is that all threads "bookmarked" here -- with red dots -- disappear. It's probably safer to save threads as IE Favorites or Mozilla Bookmarks or equivalent.0 -
I suppose
but hope not....Hawaiian pan flute players and Water Heaters are not me.
But I do post under my own name and address...."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
- 50 Industry Classes
