condensate pump
Bill Clinton_5
Member Posts: 38
I'm so pleased with the Prestige boilers we've been installing, I want to offer in situations where there is no gravity path to drain condensate. A pump can get the water out, but it needs to be a reliable one and there needs to be an interlock with the boiler so pump failure won't cause condensate to flood the house.
Looking for recommendations for pump and interlock. Any suggestions?
Thanks.
Bill Clinton
Thanks.
Bill Clinton
Your standard Honeywell works great and has a built in float switch which can be wired in series or not. It can be installed with or without a flow check. There have been good threads about neutralizing condensate as well....
TimJust a guy running some pipes.0
