veha or other panel radiators?
[Deleted User]
I just installed a bunch of the biasi panel rads. they were cheap and look good to.
my first munchkin install ...
is about to happen, with assist from a fellow-tradesperson who has put in a bunch of them. just to make life a little more complex, I'm doing a last minute wonder about using panel radiators with TRVs rather than the conventional baseboard convectors. the house is in a cold climate with good solar exposure and has a woodstove, so I can see definite plusses for individual panel control.
my main question is if anyone has recommendation of preferred brand of panel radiators? lower cost will likely be a primary criteria.
thanks as always - Roy0 -
where ...
did you get them? I haven't checked with my wholesalers to see what they carry, but I'm guessing their options for panels radiators is going to be limited.0
