Cool Thermostat
jackie c
Member Posts: 7
Need to know whats out there to incorporate three systems in one simple thermostat.I have radiant heat,Ac and supplemental heat from a heat coil in the air handler piped from the boiler.Right now have two sinle thermostats for heating and cooling because each system was started at different times.Air handler wire still poked in the wall behind thermostats,have never needed untill recent damper failure,sure could have used it then ,took awhile to get the house back up.Looking for something not too complicated.Kind Regards
Tekmar 545
2 stage heat, one cool, sensor option
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
