buderus question
Dan C.
Member Posts: 248
If you do not use the thermostatic radiator head is there something they sell to cover the valve that sticks out on the top corner?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=329&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
I thought that they
had a screw-on cap which also snugs down the valve manually to the closed position. I think the valves are made by Oventrop and have fine threads.0 -
Yellow knob..
On my buderus panel rad's my wife painted the yellow cap's white. They blend riht in w/ the wall's. I hav'nt seen anything to cover the yellow knob, good luck.0 -
Dan,
YES!!! They make a white cap with a dark "inner ring" that attaches to (read: has to almost be punched on) the inlet of the radiator. It can be used to shut the flow down also...and looks a darn sight better than the yellow or red end covers from the box.
I don't have a part number, but can probably dig one up if needed....or you may try Buderus.net. Maybe they have it listed under radiator accessories.Good luck. Chris0 -
thanks
Thank you chris. I will check the web site. i'll let you know if I need the part number. I figured there would be something that looks better than the red cap. Thanks again
- 167 Indoor-Air Quality
