Cycles/Hour Setting for Honeywell Thermostat for Hydro-Air
Bill W@Honeywell
Member Posts: 164
6 CPH for forced air. You may want to investigate a time delay, that allow the coil valve to open first on a call for heat, allowing the coil to warm, before the fan starts. That will avoid a momentary chill breeze from the system, especially on a cold day.
Cycles/Hr Setting for Honeywell Thermo Hydro-Air System
Wondering what is the best cycle/hour setting to use on a
hydro air system. My System consist of a Weil-McClain bolier and ADP airhandler(s). The Honeywell options are for forced hot air (6cycls/hr) and hot water (3cycles/hr).
Thxs
The 2 different brand of Air Handlers installed (did an addition last year), ADP and Firstco both delay approx 45 seconds before turning on the airhandler fan.
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
