Bad Job Pictures
Steve Ebels_3
Member Posts: 1,291
I wish I would have saved it. The dryer was vented into the chimney right above the flue pipe for the oil burner. Can;t remember where I saw it.
Bad Job Pictures
Hi Guys,
Well, it's that time of year again....a new heating season (along with a few hurricanes) is bearing down on us and so is the Fall training season. I will be embarking on a tour that will take me to such garden spots as Watertown NY, Buffalo NY, Pittsburgh PA and St. Johnsbury VT. In the past you have stepped up to the plate and delivered some fabulous pictures of "how not to do it" which I used in the "Things That Make You Go Hmmmm" presentation. If you have seen something that made you go Hmmmm and have a picture, please post it here and I will add it to the show.
Thanks in advance,
Bruce0 -
Not sure if these made the last post...Just a guy running some pipes.0 -
I took the fluepipe down so the beauty of the piping was fully visible.The ball valve between the boiler and relief valve is nice!
Do you have more info about the Fall training?0 -
Ball valve
How else are you going to stop a relief valve from dripping?
- 167 Indoor-Air Quality
