Kick space heater question
Tony_23
Member Posts: 1,033
Is set at 140 if I remember right.
Bypass it, wire in a SPST relay controlled by the thermostat in parallel and let the fan run on any call for heat. I'd probably set the fan on low speed.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=384&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
We installed an outdoor reset control on an existing system which has a kick space heater. Is there a basic "lower temp" clip on switch out there or do I need to throw on some basic honeywell strap on unit?
Thanks,
Gary
Is that not a common issue, Gary!
I have reset and a KS Heater too... the button A-Stat never does it as you found. So I use a line voltage thermostat and control the fan directly that way. Sure, it may blow cooler air than I would like sometimes but it is serving an entry, not my kitchen.
Because the heater is supplemental and I do not rely on it as primary, it works for me.
I had thought of putting on a Johnson or Penn strap-on aquastat or better yet a Ranco digital controller (all less than $50 last I checked) but I already had a line voltage stat hanging around so took the short route. Not perfect but it works.
Given a choice and if I relied on the KSH more, I would put on a Ranco controller.
My $0.02
Brad0 -
option for low temp
Gary,
Beacon-Morris has an optional clip on sensor for low temperature applications.This from their insatllation manual: "An optional low temperature aquastat, 120° to 105° F (49° to 41° C) is available." for about $12 PN 3024-10
- 120 Geothermal
