Unwanted gravity circulation
Hello,
I hope someone can help me with this. I'm the owner of 2 60 year old duplex equiped with a hot water/oil heating system. The furnace is 10 years old and is working properly. But since i replaced one of the 2 pumps (the house is seperated in 2 sections) i'm faced with unwanted natural circulation that's very inconvenient during the first weeks of heating and when springs comes.
I checked the valves and from what i can see, the only valves installed are Thrush gravity control valves dating back to the time that the system was gravity controled. (but i'm not 100% sure the valves are really gravity control valves). The maintenance technician thinks that the valves can work as antigravity valves if properly adjusted. Is this true ?
If the current valves can't do the trick, and since my furnace works to keep its tank water always hot, is the only solution to install a antigravity flow valve ?
Thanks for any help.
Etienne St-Cyr,
Montr
